DIAdem
treat editboxes as array
Hi
I have a SUD dialog with a number of editboxes - editbox1 to editbox13 - can I treat the edit boxes as if they are an array so can set the contents in a loop
for example editbox(i).text = text
I've tried but with no success and was wondering if I was missing something obvious.
Nick
(4,507 Views)
Hello Nick!
The way you have tried is not implemented but there is a solution with the VBS command 'Eval'. Eval evaluate an text expression during runtime an returns the result.
Try this code:
Dim i
For i=1 To 13
  Eval("Editbox"&i).Text = i
Next
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,506 Views)
Hi Matthias
Problem solved
Thanks for the help
Nick
(4,502 Views)
Hi Nick,
Note also that there is a similar command called "Execute" that runs the rest of that command line after parsing it.  Alternatively, you could use a table control in your SUDialog, and then you could really address those cells like an array, though you have much less flexibility that way in the vertical or horizontal arrangement of the text boxes.
Brad Turpin
DIAdem Product Support Engineer
(4,479 Views)
Hello!
Brad is - as always - right! It is possible to use Execute instead. IMHO Eval is a little bit better because you are not running into problems with string delimiters, you can assign the Eval result to a variable or use it in a with command and the code is much more readable.
Matthias
Matthias Alleweldt
Twigeater?
(4,470 Views)
