DIAdem
tdm data path defination
I have a problem here, when i want to define the path of the testet data. How can I correct,that the data can be loaded in path C:\Dokumente und Einstellungen\TDM. Maybe someone can help. Thanks a lot.
ReDim
DataFilePaths(fMax)
DataFilePaths(1) = AutoActPath & "2012-05-14 1834 VF-028 Nano IMT Indonesia-Java.TDM"
DataFilePaths(2) = AutoActPath & "2012-05-15 2206 VF-028 Nano IMT Indonesia-Java.TDM"
CallDataFileLoad(DataFilePaths(f))
Message 1 of 14
(6,359 Views)
It is always the warning: Die Data "C:\Dokumente und Einstellungen\TDM2012-05-14 1834 VF-028 Nano IMT Indonesia-Java.TDM" can not funden.
Message 2 of 14
(6,358 Views)
Hi andreasyou,
You can use the commad FileEx
ReDim DataFilePaths(fMax)
if FileEx(DataFilePaths(f)) then
else
  msgbox f & " dosen't not exist"
end if
Greetings
Walter
Message 3 of 14
(6,353 Views)
Hello Walter,
thank you for your help. I just use diadem 11.0 and try  this commad FileEx . Then comes the warning, i must FileEx define. This exists not in the Diadem Help. I thought it works in diadem 2012.
Best Regards
Andreas
Message 4 of 14
(6,349 Views)
That's my fault. The command is FilEx.
Message 5 of 14
(6,346 Views)
Hi Walter,
now the commad is right and the data is loaded, but there is no value in the channel. Is the problem of AutoActPath?
Best Regards
Andreas
Message 6 of 14
(6,340 Views)
Hi Andreas,
No, I don't think not. Can you post this dataset?
Greetings
Walter
Message 7 of 14
(6,337 Views)
Hi Walter,
this is my script. Thank you for correcting.
Message 8 of 14
(6,334 Views)
I meant the dataset you are going to load. I just want to check whether the dataset is OK.
Message 9 of 14
(6,332 Views)
sorry,i have missunderstood. Can i send the data to your email box?
Message 10 of 14
(6,330 Views)
