DIAdem
sud dialogs in Diadem 8.1
I am using Diadem 8.1. I am trying to make dialog boxes using SUD. I have a file in which i define what are vairables are and i call this file in VBS using:
If not VSA("FlexDP") Then
Call USERVARCOMPILE("FlexDP", "new")
End If
Now the problem is: For eg: in this file i declared my variable Asciidata$: B In my SUD dialog if i call Asciidata_ = "True" it does not like it and it throws an error saying "Error message from Diadem OCMD-interface. Invalid CMDID Type of Diadem-designator [Typ="ASCIIDATA_"]!"
If i change Asciidata_ to Asciidata in my SUD it works fine but when i say "Call msgboxdisp(Asciidata_)" in VBS it gives me an error. I really dont know where to fix this. Thanks!
Shefalika
(3,718 Views)
An an update: I changed Asciidata$ : F in my vas file and then it worked fine. But it does not like Asciidata$ :B. Does anyone know why? Thanks!
(3,712 Views)
Hi Shefalika,
I just wanted to let you know that I am looking into your issue and will post a response for you as soon as I can determine what may be going on here.
Caroline Tipton
Data Management Product Manager
(3,689 Views)
Seems to me that you are trying to put the string "true" into your boolean variable.
Try asciidata$=True instead of asciidata$="True"
edit: but be careful with bollean variables in DIAdem/SUD.
When displaying a boolean variable you have set to TRUE or FALSE in a textbox in SUD, it will display YES or NO. In other circumstances it will be set to 1 or 0.
So perhaps it is easier to just use an integer and set to 0 or 1.
Message Edited by themad on 09-28-2005 06:40 AM
(3,677 Views)
Another thing you want to double check is your spacing.  You must have a space on both sides of the colon in your variable declaration.  So,
ASCIIDATA$ : B   this will work
ASCIIDATA$ :B    this will not work
Hope this helps.
Caroline Tipton
(3,668 Views)
