DIAdem
subscript execution with a variable name
Is the a way to run a subscript where the name is a dynamic variable? for example:
SubtoRun = T1 (T1 is a diadem text variable which is the name of the sub to be run)
Call SubtoRun
(3,071 Views)
Hello Bill
You can use the Execute command, e.g.
sub test
msgbox "hallo"
end sub
t1="test"
execute t1
Hope this helps!
Winfried
(3,067 Views)
