01-15-2013 05:12 AM
Hi All,
I have been working with a channel with the data type String and fill in values with a script. This channel gets really big, it has been over 4 000 000 values long some times. It worked perfectly fine just last week. When I tried to run my script today it woud throw an error message that the index 262145 is outside the valid range for the values property.
Numeric channels work ok and I didn't change anything in the script related to my channel.
What could be the problem?
Christoph
Solved! Go to Solution.
01-16-2013 04:47 AM - edited 01-16-2013 04:50 AM
Hi Christoph!
Can you send me the error code you get with your message?
I'd like to take a look at this.
Eduard Gross
01-16-2013 05:01 AM
Hi Eduard,
That's a bit embarrassing... I've tried everything but restartung DIAdem...
It was merely a lack of memory. Sorry to have bothered you.
Christoph
01-16-2013 06:30 AM
Hi Christoph,
that's not a problem.
I'm glad to hear you got the issue resolved.
Have a nice day,
Eduard Gross
