DIAdem
specific script problem
I built a script that his funtions are:
-Create some new channels:
1- "DAYS" channel: I want here to appear each day without repetitions (ex: 22/11/2003, 23/11/2003...27/11/2003)
2- "BOXNew" channel: The same as the Days channel but now in "box" (ex: 1,2,3,4,5...12)
3- "CONS#" channels: I want here to appear the daily consumption of each box. (ex: Channel "CONS" -> first value belongs to the daily consumption of the first box and the first day, 2nd value belongs to daily consumption of first box and 2nd day...Channel "CONS1"-> 1st value belongs to consumptions of 2nd box and 1rst day...)
-Calculate total consumption of each day, average and standard deviation.
The problem is that by some reason, the "DAYS" and "BOXNew" appear as NOVALUES.
Does anyone have a solution to this problem? Or does anyone have another way to make the same as my script?
The Days and the BOXES change each time I run a new report.
I work with Windows XP& DIAdem 9.0.
I attach the tdm, tdx and vbs files.
THANKS!
Nuria
(3,413 Views)
Hello Nuria,
a little bit tricky but it works fine. Hwo du you get NOVALUES in the channels "BOXNew" or "DAYS"? I have no NOVALUES in this channels.
Andreas Weiland
Projektingenieur
measX GmbH & Co. KG
, www.measX.com
(3,396 Views)
