DIAdem
smoothing a decreasing step function
i have a step function (red graph) which I want to smooth. The smooth function should proceed through the middle of the step (black graph). How can I do this in Diadem?
(2,773 Views)
Do you have a sample data set that you can share ?
Have you tried the Smooth function in Analysis > Curve Fitting ?
http://zone.ni.com/reference/en-XX/help/370858N-01/dlgmaths/calc_graphs_dlg/dlgchnsmooth_dialog/
If yes, what is the result of the smoothing you get ?
CLAMaxime -- Kudos are a great way to say thank you
(2,770 Views)
