Hi arkangel,
The GroupDefaultSet() command changes the default group, but that only affects ADDITIONS to the Data Portal after that point, such as new FormulaCalculation channels, excerpted section channels from VIEW, new ANALYSIS channels from an FFT calculation, etc.
If you want to reference channels of the same name from multiple groups, and you have DIAdem 9.x, you can use the [GroupName]/[ChannelName] adressing scheme to query off the "Time" channel from multiple groups. If you have DIAdem 9.1, then you can also use the [GroupIndex]/[ChannelName], [GroupName]/[ChannelIndex], or {GroupIndex]/[ChannelIndex] adressing options. For example:
For i = 1 TO GroupCount
ChNum = CNo("[" & i & "]/Time")
IF ChNum > 0 THEN Msg = Msg & "Group " & i & " --> " & ChnLength(ChNum) & vbCRLF
NEXT
MsgBox Msg
For DIAdem 8.x you will need to use the CNo() function's optional second parameter (ChannelNoStart) in order to ensure that you start at the next channel AFTER the one you just found. Channel numbers was all there was in DIAdem 8.x.
Brad Turpin
DIAdem Product Support Engineer
