09-07-2006 04:16 AM
09-07-2006 08:42 AM
Hi Thomas,
Double-click on your REPORT legend to open up the legend configuration dialog box. If you have DIAdem 10.0, you also need to select the "Labels" tab. Now switch from "Channel Name" labeling to "Free text". In the area where you type in the free text, enter an expression like this:
@CN(#)@ [@CD(#)@]
CN (ChnName) returns the channel name
CD (ChnDim) returns the channel unit
# (CCN) returns the Current Channel Number of that particular curve
Cheers,
Brad Turpin
DIAdem Product Support Engineer
09-07-2006 08:44 AM
Hi Thomas,
for each y-axis you have a free axis-text. doubleclick to the axis to fill in what you want.
if you have a unit saved to a channel (ChnDim or CD) then you can use that in your axis-text or in your legend like the following:
@CD(CCN)@.
i hope, this was what do you looking for.
remark:
better than using the jpg-format is the png-format:
is has a better quality and almost the same size as jpg-files
09-07-2006 09:19 AM - edited 09-07-2006 09:19 AM
THX for your respond but I look for somethink else. When you have a chart like attached, you do have for each scale it's text. I would like to have this as well for the N System.
But I guess it does not work, right?
PS: I know about png. A workmate did it and I guess the comprimation was very low 😉 but thx anyway 🙂
Thomas
Message Edité par tom_the_dude le 09-07-2006 09:20 AM
09-11-2006 02:32 AM - edited 09-11-2006 02:32 AM
Hi Thomas,
my English seems to be not very good... sorry about that.
i thought, that you are looking for a chart like attached.
the way how to do was already written.
Message Edited by hass on 09-11-2006 09:33 AM
09-11-2006 02:51 AM - edited 09-11-2006 02:51 AM
Message Edité par tom_the_dude le 09-11-2006 02:52 AM
09-11-2006 03:06 AM
Hi Thomas,
if you use the v.10.0, double-click to the n-system. there you should find it shown in the attached file with the red ellipses.
it's only the german version, i hope, you find it in your language.
09-11-2006 03:23 AM
Thanks a lot 🙂
I didn't see that.
Thanks again!
Thomas
12-12-2007 01:14 AM - edited 12-12-2007 01:16 AM
12-12-2007 03:37 AM
Hi Martijn,
sorry I'm not sure if I understand you. What are you looking for?
1. y-axis over each other like my attachment before (see att. axis_over_axis)
2. more ticks for an axis - not like 0,5,10,15,20... like 0,2,4,6,8,10... (see att. more ticks)
It's v8.1 and in German but I hope you will find it in your version / language!
