01-12-2007 07:04 AM
01-12-2007 08:05 AM
01-12-2007 10:19 AM
Hi Ken,
thanks for the answer.
I actually wanted to know if it was possible using the features of the Report panel of DIAdem without modifying any data.
Your solution is ok, but it requires :
1-splitting the waveform channel into X and Y channels
2-Modifying the X channel (thus creating a imaginary one) without changing its length (if the length changes either X or Y channel will be shorter than the other, which will result in wrong representation of the curve)
In the area where you want to have a better visualization, one has to increase the distance between two sequential x points by a factor . For example (x2_new - x1_new) = 4*(x2_original - x1_original). This will change the time range in the x channel.
3- Loading the original Y channel with the imaginary x channel in the report.
4- In report ; deleting the numbers in the x axis (because they are wrong values)
5- mark the time value between two ticks(1unit) in different parts of the graph.
And after all this is more Analysis then reporting !
I hope there is an other way to solve this problem
regards
Kaan
01-12-2007 11:15 AM
Hello Kaan!
The short answer is: No
As far as I know is there no build in way. You need a multiple X axis scaling, but there is only a single scaling in DIAdem.
Every solution aproach will result in a calculation process or an uncomforable layout design.
I see two aproaches:
Sorry that I can't give you hope for a simple and good solution.
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
