DIAdem
return value for TextFileOpen does not match help system
The help system indicates that TextFileOpen "retuns the value 0 if an error occurs when opening or creating the text file".
When I run the following with DiaDem 2010SP1 on Vista64, I get value of -1 ...
                   MsgBox  TextFileIOpen("This File Does Not Exist.csv",tfRead)
This means that any error checking using that function might not work as intended.
(3,604 Views)
Hello Colin Jones,
Thank you for this information. You are right. We will change the DIAdem help system so that the descrition reflection the correct return value in VBS.
Greetings
Walter
(3,592 Views)
