DIAdem
programmatically capturing user actions in report window
I'm trying to build an interface that allows a user to run a deeper analysis based on what he sees on a report, and for that I need to be able to get the information of which element of my report the user is clicking on. I have looked pretty much everywhere, from the Diadem help to forums to the wider internet, and was surprised to find absolutely nothing on the subject. So I am wondering if it is at all feasible, and if it is, what am I missing?
Many thanks in advance for any information you might provide
(4,306 Views)
Accepted by topic author MaxLek
Hello MaxLek,
It is possible to get the information about the selected objects in REPORT. Here is an example.
dim iLoop, oCurrSelection
set oCurrSelection = Report.SelectedObjects
for iLoop = 1 to oCurrSelection.Count
  select case oCurrSelection(iLoop).ObjectType
    case 0
      msgbox "2D-Axis"
    case 1
      msgbox "2D-Table"
    case 2
      msgbox "Polar"
    case 3
      msgbox "3D-Axis"
    case 4
      msgbox "3D-Table"
    case else
      msgbox "all other"
  end select
next
Hope this helps.
Greetings
Walter
(4,301 Views)
That's perfect, thanks so much Walter
regards,
Max
(4,297 Views)
