DIAdem
powerpoint export template
Hi , I'd like to insert the company logo in the PowerPoint template.
Insert the logo from the slide master and it will go off the screen
sally23_1-1622516431691.png<-  image1
On the slide master, it's on the top left, but on the powerpoint, it looks like image 1.
sally23_2-1622518485772.png<- powerpoint
(4,069 Views)
Hi Sally,
Would you please send your TDR file and Powerpoint master file that you're using?  I'm struggling to reproduce the effect you have documented in screenshots.
Brad Turpin
Principal Technical Support Engineer
NI
(3,980 Views)
hi, I solved this problem. Thank you
But can't I change the order of the powerpoint? I wonder if I can remove pages of 2,3,4 of PowerPoint if I export it as a powerpoint in the diadem.
(3,971 Views)
Hi sally,
If you're exporting to Powerpoint using a script, then you can toggle to FALSE the "UseForPrinting" property of each sheet you want to NOT include in the export to Powerpoint (or image, or PDF, or...)
Report.Sheets(2).UseForPrinting = FALSE
Report.Sheets(3).UseForPrinting = FALSE
Report.Sheets(4).UseForPrinting = FALSE
Call Report.Sheets.ExportToPowerPoint(PowerpointFilePath)
Brad Turpin
NI
(3,949 Views)
Thank you.
I have another question.
Can you remove the border of the diagram when exporting it from diadem to powerpoint?
I want to erase the lines on the image. Is it possible?
(3,943 Views)
Accepted by topic author sally23
Hi sally,
Yes, I always prefer to suppress that border line when I'm exporting to a report file as well.  You can open up the TDR file you're using, pop open the "Layout Parameters" dialog for that TDR file, uncheck the "Display Frame" checkbox, then hit "OK" and re-save that TDR file.
Or if you prefer to toggle this setting programmatically, try this:
Report.Settings.Page.BorderVisible = False
Brad Turpin
NI
(3,915 Views)
Hi Brad
Thank you always for your kind explanation.
(3,878 Views)
