DIAdem
pdf table 2D multipage
Good morning,
Based on an example of the forum, I've created the attached vi, to save to a pdf file, a series of pages created in Diadem, of which there is a page that contains a table 2D, which may contain a different number of data, and consequently may be several pages.
I do not know what I'm doing wrong, so I only print the first and last pages, when in the example, in theory I have it ready to print twice the entire table.
Any suggestions?
(4,468 Views)
Hello aristoy,
I don't know why it doesn't work but if you use the command PicPrint instead of PicPdfExport it will print the entire table twice.
Dim j
Dim intCount
Call DocStart()
Call GraphSheetInfos
For j = 1 to GraphSheetCount
  ' Set Printer Port for DIAdem PDF Export
  PrinterName = "winspool,DIAdem PDF Export,NUL:"
  PDFFilename = "D:\diadem_report_gen_edited\xxx.PDF"
  PrintRangeType = "PageEnums"
  ' Set these variables to the current sheet we're going to print.
  PrintFromPage = j
  PrintToPage = j
  ' Show the current sheet we're going to print,
  ' so that PicMaxPageCalc will know which one it is calculating for.
  Call GraphSheetNGet(j)
  Call GraphSheetShow(GraphSheetName)
  ' Calculate how many pages this sheet will take.
  Call PicMaxPageCalc
  For intCount = 1 to MaxYPage  ' Print all pages of the table
    CurrYPage = intCount
    PicPrint("WinPrint")
  Next
Next
Call DocEnd()
Hope this helps!
Heike
(4,400 Views)
