Hi BAS,
How are you loading these CSV files? Are you simply dragging them from the NAVIGATOR into the Data Portal, are you using the ASCII Import Wizard, or are you using a custom DataPlugin you are creating? In the last two cases you can specify the time format contained in the file as part of the overall configuration.
There is no way to configure the drag&drop behavior of the CSV file importer, though if you call it programmatically there are a few options. In general, though, the CSV file importer that is used when you simply drag&drop a *.csv file from the NAVIGATOR into the Data Portal does a good job of interpreting non-US date/time formats. It was created in Germany with Europeans in mind. Does your CSV file have the European-standard semicolon (";") delimiter or US-standard ("," or tab) delimiters? What is the decimal character in your data columns ("." or ",")? What is your date delimiting character ("-", "/", or ".")?
Feel free to send over a sample file for us to test here, I'm confident we can read them into DIAdem without you having to rewrite their date/time stamps.
Brad Turpin
DIAdem Product Support Engineer
