DIAdem
mehrere Systemvariablen auf 0 setzen
Hallo,
nach jedem Zyklus möchte ich die Systemvariablen auf 0 setzen.
R1=R2=R3=R4=R5=R6=R7=R8=R9=R10=R11=R12=R13=R14=R15=R16=R17=R18=R19=R20=R21=R22=R23=0
funktioniert aber nur für R1.
Habt ihe einen Tip, wie es funktioniert, ohne explitit jede Variable einzeln auf 0 zu setzen?
after each cycle I want to set the system variables to 0.
R1 = R2 = R3 = R4 = R5 = R6 = R7 = R8 = R9 = R10 = R11 = R12 = R13 = R14 = R15 = R16 = R17 = R18 = R19 = R20 = R21 = R22 = R23 = 0
but it works only for R1.
Do you have any idea how it works without explicitly set each variable individually to 0?
(2,905 Views)
In VBS your code will become and logical expression comparing all of them setting true or false to R1.
You either have to write each of them or you can use a loop.
dim i : for i = 1 to 23 : execute("R" & i & "=0") : next
I am not sure if a loop is a good aproach because you will never be able to find that the R variables are assigned using this line.
If you just fear multiple lines the : is your friend.
R1 = 0:R2=R1:R3=R1
(2,888 Views)
Thanks!
(2,883 Views)
