DIAdem
import teststand html result
I have to collate loads of teststand HTML result files.  This is a most onerous and tedious process.  As the format is created for the HTML by NI does anyone know if there is a way of importing the data in Diadem?
Sean
(3,913 Views)
Hi Sean,
While TestStand does by default report in HTML format, you can change this by going to "Configure >> Report Options" and changing to to a preferred standard such as ATML: http://zone.ni.com/devzone/cda/epd/p/id/5829
Kind Regards,
(3,888 Views)
Hi Sean,
If you can change the report type to either ATML or XML, then we can read those report file results into DIAdem with a corresponding DataPlugin.  I'd also be willing to help you with this.  There is no HTML import option available.
Brad Turpin
DIAdem Product Support Engineer
(3,859 Views)
