DIAdem
how to convert tdm file to txt
i have a tdm file that i would like to convert to a txt file.  thought i could just go to file save as but didn't have that option, is there another way?
(5,527 Views)
Hi Cmiranda,
You can select the menu "File --> Save as". In the dialog you can choose "CSV" as file type. That saves all data as comma separated value.
I hope this will help you.
Greetings
Walter
(5,514 Views)
Hi cmiranda,
It actually saves the file as tab-delimited, with a CSV file extension.  There is a way to parameterize the CSV export to output comma separators, but that is only from a VBScript.
Brad Turpin
DIAdem Product Support Engineer
(5,503 Views)
I tried doing what you mentioned, but I don't have CSV as a file type that I can save to.  I only have .dat, .tdm, .atf, .usf, and .xls.  Also, is there a way to do a batch "Save As".  I have over 100 files that I want to save as .txt (or any other format that I can open anywhere) and I don't want to have to go through the renaming process.
--claudia
(5,450 Views)
Hi Brad,
please tell me the way, switching to a comma-seperated output.
I hope to find this parameter "at the surface" in DIAdem 10.
Regards
Martin
(5,444 Views)
You can use the command DataFileSaveSel to save your datafile in the correct format.  You can see how to use this command to save a CSV file as comma delimited in this post.
Let me know if you have any questions about the command.
Caroline Tipton
Data Management Product Manager
(5,424 Views)
