DIAdem
how to change channel status (readonly to write mode)
i created one channel using ChnLinGen(E, GenXBegin, GenXEnd, XNo) It created the channel which is read only from which i am not able to delete values or change channel length. How do i make it a normal channel back again. See attached jpg for the error which got while using the command DataBlDel()
(4,335 Views)
Accepted by topic author GDU
Try the ChnValExpand command.
It expands registered or implicit channels into a DIAdem standard channel.
Call ChnValExpand("Time")
(4,327 Views)
thanks i worked.
(4,325 Views)
