DIAdem
group count
Does anyone know if there is a function to calculate the amount of Groups? I know there is one to calculate the amount of channels: ChnNoMax but I can't find one to calculate the amount of groups
Basically what I want to do is to erase all the groups in the data portal to start with an empty data portal. For this, the only function I know is: "Data.Root.ChannelGroups.Remove(groupnumber)" and I want to use it in a For loop but for this I need to know the last value of the For Loop which is the number of groups...
(7,121 Views)
Accepted by topic author Leillo
Hi Leillo,
To count the number of channel groups use
Data.Root.ChannelGroups.Count
Please play a bit with the Data-API we implemented in DIAdem. It contains all data you see in the Dataportal. You can also have a look at the DIAdem script example. Most of them use it.
Greetings
Walter
(7,118 Views)
(7,102 Views)
Please use
data.Root.Clear
 to start with an empty portal and do not loop over all groups.
(7,088 Views)
Even better, thank you
(7,081 Views)
