DIAdem
generate vertical lines on a graph using VB script
I want to draw vertical lines onto a 2d-axis graph in the report I create with my script. The lines need to be at two x values I calculate with my script. Are there any code examples of this?
Matt
(4,431 Views)
Hello Matt,
Please store the two calculated values into a new channel and create another one to specify the corresponding X values. Then just draw that curve.
Greeings
Walter
(4,403 Views)
Hi Matt,
Alternatively, try using the "Constant" curve type and specify either the value of the X coordinate or an expression that will resolve to that value in the "X-constant" field of the curve configuration.  If you want to draw vertical lines at the same X coordinates over and over again, this may be even simpler than creating channel data.
Brad Turpin
DIAdem Product Support Engineer
(4,391 Views)
got it working, thanks for the help!
(4,385 Views)
