DIAdem
font is changed when print out and other issues
I need help with some of my issues with Diadem. I am quite new with Diadem.
I use Diadem to generate report from teststands. The data is passed from Teststands - VI using Diadem connectivity toolkit and a VB script is called to generate PDF and print out the computer.
1. First issue: the font on the diadem looks different with the one is printed out or in pdf. The font in pdf is bigger than in Diadem. You can look in my screenshot.
2. Second issue: sometime it cannot export pdf and the error message is Cannot open the .pdf file.
3. I need to get the channel name and the content of it in the script. Could you please tell me how to do it?
Thank you for your help!
(6,094 Views)
I also include here the script.
(6,092 Views)
Hi NTT,
Would you please post your *.TDR file that contains the REPORT layout?
Brad Turpin
DIAdem Product Support Engineer
(6,069 Views)
Brad,
This is the layout.
Thank you!
(6,065 Views)
Hi NTT,
I was able to print a PDF file that looks good, though perhaps the missing link for me is the master layout file you haven't sent yet:
D:\G2\Scotsman_PS_EOL_Test_System\Software\Code\Support\Report\Scotsman-Ice Master Layout.TDRM
Brad Turpin
(6,053 Views)
Brad,
The master layout only has a logo so I think it is unnecessary.
The problem is sometime I got a good print and sometime I got a print with wrong font. That's why I don't know how to fix this issue.
Thanks!
Thang Nguyen
(6,023 Views)
