DIAdem
find first 5 values in a channel
how can i find the first 5 values of a channel where the channel value will be 6.5..
For eg:
0
0.1
0.21
3.1
6.1
0.3
6.1
6.1
6.1
6.1
6.1
6.1
6.1
4.2
3.2
0.3
0.1
I want to the row where my channel value will be the highest(Peak search) and it continues for minimum 5 values(may be more also)
Thanks in advance,
Rsh
(4,682 Views)
Hello Rsh,
you have several possibilities to find a peak with DIAdem.
The command ChnPeakFind returns peaks contained in the signal. But I think the command ChnFind is better for solving your task. The ChnFind function searches a data channel from the beginning to the end, e.g.
dim i, count
dim intMyResult, intOldResult
FOR i=0 TO ChnLength("Tabelle1/channel1")
  intMyResult =  ChnFind("instr(1,ch(""Tabelle1/channel1""),""6.1"",vbTextCompare)<>0", i) ' search 6.1
  if ((intMyResult - intOldResult) = 1) then  ' Compare old position and current position
     count = count + 1 ' count the number of the value 6.1
     if (count > 4) then
        MsgBox(intMyResult) 'Display the position of the 5th 6.1 value
     end if
  end if
  intOldResult = intMyResult
NEXT
My code doesn't not exactly what you want to do, but I hope it helps you to find a solution for your problem.
Best regards
Heike
(4,653 Views)
