10-28-2005 12:22 PM
10-29-2005
10:02 PM
- last edited on
09-12-2025
01:04 PM
by
Content Cleaner
Hello Mr Bean,
There are several major differences between the two solutions. I'll try and outline them as good as I can ...
The biggest different is that LabVIEW and its toolkits are programming tools and DIAdem is a ready to run application.
The LabVIEW Report Generation Toolkit basically provides an extensive library of VIs that allow you to connect LabVIEW to the MS Office library and create and edit reports in Word and Excel.
DIAdem is a stand alone application that was designed to post-process data from various sources. The tools included in DIAdem are:
1. NAVIGATOR: Allows you to import data from files (ASCII, binary, Excel, etc.) as well as DataBases (SQL/ODBC, Citadel, ASAM, etc.). The unique DataPlugin technology available within DIAdem allows you to import vitually and data file by creating a DataPlugin that describes the data format and gets linked to DIAdem. More information at: https://www.ni.com/en/support/downloads/dataplugins.html
2. VIEW: Graphical and Numerical data inspection tool. Use cursors to zoom and scroll through your data, edit your data graphically and numerically and compare different tests.
3. ANALYSIS: DIAdem has a wide range of analysis functions, ranging from simple functions like integration and differentiation to FFTs, Order analysis and 3D data analysis.
4. REPORT: The DIAdem REPORT tool allows you to create reusable report layouts that can contain multiple axis systems (2D, 3D and polar plots) as well as tables (2D and 3D) and variables. The REPORT tool generates templates that can be usedwith multiple data sets due to the inclusion of automatic (or manula if required) scaling as well as extensive use of variables for annotations. Finished reports can be exported to printers, graphics files, the Windows Clipboard, HTML pages and PDF files (PDF writing is build into DIAdem, no extra software required). Using Scripts, it is also possible to create Word, Excel or Powerpoint reports from DIAdem automatically.
5. SCRIPT: The DIAdem scripting tools allows users to record macros or write scripts that automate complete sequences, for the import of data, via extensive analysis, to creating a publication ready report. Scripts can make reports "intelligent" by modifying the appearance of a report based on the data or calculation results that are going to be displayed in the report.
I recommend you check out the following link for more information: https://www.ni.com/en/shop/data-acquisition-and-control/application-software-for-data-acquisition-an...
DIAdem is an extremly powerful tool for report generation. I am leaving to go on a business trip to Asia, but I would be more than happy to give you an Web presentation on DIAdem after I have returned. We could use your data and create a DIAdem report Script together online. My Email address is otmar.foehner@ni.com and I will be back the week of Thanksgiving.
Otmar
