DIAdem
convert float to date
Hi all,
I want to display a formatted date/time on a report with two common text fields. Therefore I read out the min and max from a time channel. But all I get is this float64 coded time. I didn't find any method to convert this to a date object which I can format. Is there a possibility to get the two values as a VBScript Date object? Or which procedure do I have to follow to convert this to a date/time which is human readable?
Thanks in advance,
Alex.
(3,592 Views)
Hi Alex,
The basic date/time format in DIAdem starts in the year 01/01/0000 in steps of 1 second. In dialogs or tables this will be converted in a readable date/time format automatically. If you would like to work with a date/time value it is sometimes necessary to do this converting by your own. For this DIAdem provides the commands:
TTR : Converts time format text into the number of seconds since 01/01/0000.
and
RTT : Converts a positive number into time format.
Please refer to the DIAdem help for detailed information’s.
Greetings
Walter
(3,588 Views)
Walter, thanks alot. That was the method I was looking for. Works.
Greetings, Alex.
(3,585 Views)
