DIAdem
compile VBS
Hi, in my application I use a VBS script.
Is it possible to protect or compile this script (like AUT->AUC) to avoid that the customer copy or modify the code of the script?
(3,801 Views)
Hi MicheleS,
Please choose DIAdem-SCRIPT and select Script»Encrypt VBS script/SUD file. In case you are using an older DIAdem version you might have to use the command AutEdEncode instead.
Hope this helps,
Ralf
(3,793 Views)
Hi Ralf, thanks a lot for your repley !!
have a nice day
(3,789 Views)
