DIAdem
change marker color of specific points in scatter plot
Please check my attached image. The scatter plot shows performance of an generator: fuel flow vs generated power. The data points used for this plot are from the last 3 month data. I would like to highlight the data points from the last month. How can I change the color of those data points?
Thank you
(3,931 Views)
Accepted by topic author levan8421
Hi levan,
Your only option is to make a new curve with a different color/size/marker and plot just the points from the last month.  That means you also need to carve out the data from the last month from those X and Y channels and make new, smaller X and Y channels that this new curve plots.
Brad Turpin
DIAdem Product Support Engineer
National Instrumentes
(3,891 Views)
Thanks. I believe so too and I did that.
I realize that the plot is created for the whole channel only; so the format must be identical for all the data points in that channel.
(3,879 Views)
