‎01-20-2009 04:03 AM
‎01-20-2009 10:59 AM
Hi Andre,
This should work, but you should always use SudDlgCreate() when launching non-modal SUDialogs. The SudDefLoad() command stores the full file path to THAT SUDialog in an internal variable, which can mess up subsequent non-modal SUDialog callbacks.
Brad Turpin
DIAdem Product Support Engineer
‎01-21-2009 03:00 AM
Hi Brad !
Thank you for your active helps !
It works fine now ! ...
In parallel the trouble was related to an event occuring when I open the 2nd non-modal dialog (Dlg_Liste).
Another question : The non-modal dialog don't have "minimize" and "maximize" windows controls ?
Thank you again !
Andre Rako / Helion Fuelcells Hydrogen Power/ Aix en Provence (Fr)
