DIAdem
average of 2 digital displays output into a digital display
Hello all
I am working with DIAdem (Advanced 10.2) with DAC Kit. Currently I have 2 digital displays each returning a temperature from the DAC. What I need to do is display a "live"/"real time" average for this data in a digital display.  Is there anyway I can do this using the DAC Kit version?
I will grateful of any advice.
Cheers
Message 1 of 8
(5,307 Views)
Hi Osned,
Did you have a look at the "Processing" blocks in DIAdem DAC? There you find the block "Floating mean". I assume that's what you are looking for.
Greetings
Walter
Message 2 of 8
(5,281 Views)
Hi Osned,
I was wondering how you were getting on with your application.
Kind regards,
Ashish Naik
Automotive Business Development Manager
National Instruments UK
Message 3 of 8
(5,252 Views)
Morning
I have tried using the "floating mean" process. However, all the "processing" icons are "greyed" out thus preventing their use.  It appears we may have been advised/purchased the incorrect version of DIAdem, i.e. kit instead of bundle (or vice versa).  In view of the current financial climate and the high cost of the appropriate upgrade I was trying to determine if their was alternative method for the calculation of the average.
Many thanks for your interest in this matter.
Message 4 of 8
(5,247 Views)
Hi Osned,
The „floating mean“ functions are VBS functions and are installed by default (without additional costs). Please have a look at the GPI registration (menu -> Settings -> Options -> Extensions -> GPI extensions). There you should find in the “Default GPI Plugins” the file GFSVBSDr.DLL and its status should be “Loaded”.
Greetings
Walter
Message 5 of 8
(5,238 Views)
Many thanks Walter.  Will try your recommendation and report my findings.
Message 6 of 8
(5,236 Views)
Hi Walter
I've checked what you suggested and apparently the GFSVBSDr.DLL is in fact loaded
Regards
Message 7 of 8
(5,223 Views)
Hi Osned,
It seems that your first assumption is true. Do you have a license for DIAdem KIT or DIAdem BUNDLE? If you have the KIT no mathematical calculation during the measurement is possible. That seems to include the VBS functions.
Greetings
Walter
Message 8 of 8
(5,212 Views)
