DIAdem
average explicit rows
Hello everybody,
I ve been trying hard to figure the following problem out myself. I couldnt find the same problem posted so far:
On an Engine testbench I measured  several channels (power, torque, temperatures, pressures and so on).
I made a variation of fuel pressure. To get a better quality I measured every fuelpressure 3 times.
I did this with 5 fuelpressures and got a file with 15 rows.
Now I want to average each fuel pressure (creating the average of every other 3 rows for each channel).
Even though the solution should be easy I couldnt make it. It feels contrary to the way diadem works...
Maybe you can help me. Thank you very much
(3,961 Views)
Hi fabj5,
Please go to ANALYSIS -> Statistics -> Descreptive Statistics
Choose "Row oriented evaluation" and "Arithmic mean" and for "Rows" the channels you would like to calculate.
Greetings
Walter
(3,958 Views)
Hi fabj5,
Just to clarify Walter's suggestions, you want to input the rows of interest as a string in the dialog, such as:
1-3  OR  1,6,11
Brad Turpin
DIAdem Product Support Engineer
(3,945 Views)
