DIAdem
automatic change in all pages of the report
Yes, it seems that the XY-Relations are not correctly set. I will get in contact with R&D.
Message 31 of 35
(624 Views)
where can that be? by me while writing the code or by a normal file before evaluation?
here is the code for low pass filter :
Set ChnResult = ChnFiltCalc("[1]/Zeit 1 - Standardmessrate", "[1]/a-5-3 X", "/Filter-a-5-3 X", "IIR", "Bessel", "Low pass", 2, 25, 0, 0, 1.2, 25, "Hamming", False, False)
And still looking for the code for the event, as I said, I used it 15 times for 15 channels:
Call Data.Root.ChannelGroups.Add("Ereignisse -Filter-a-5-3 X ", 3).Activate()
ChnEventList1 = ChnEventDetectionWindow("Zeit 1 - Standardmessrate", "Filter-a-5-3 X", 0.5, 100, 0, 0)
ChnEventList1 = ChnEventFilter(ChnEventList1, "Peaks", 0.08, "Value")
ChnEventList2 = ChnEventDetectionWindow("Zeit 1 - Standardmessrate", "Filter-a-5-3 X", -0.8, -100, 0, 0)
ChnEventList2 = ChnEventFilter(ChnEventList2, "Peaks", 0.08, "Value")
ChnEventResultList = ChnEventOperationOR(ChnEventList1, ChnEventList2)
ChnEventList1 = ChnEventResultList
Call ChnEventCreateXYChannels("Zeit 1 - Standardmessrate", "Filter-a-5-3 X", ChnEventList1)
You mean I have to tune in a code for the xy axis for the events?
Message 32 of 35
(620 Views)
Unfortunately, it didn't quite work, as mentioned, it's about the length of each event that appears.
I limited it in the report for 12 events for each channel.
if i write code in the script for each events then it shows an error if the events don't appear.
In the picture, for example, for the channel (Filter-a-5-3 Y) there are only 6 events after the evaluation, so there is an error on line 83 because 7 events are not defined.
It seems difficult to solve the problem like this. Hopefully there is a possibility to define the problem without code for xy axis in events! maybe change something in this code directly to define the yx axis for each event.
Message 33 of 35
(615 Views)
Yes, of course have different measurement results different numbers of event matches. Here is the way I would solve that:
dim oResGroup, oResGroupChns, iNoOfMatches, iLoop
set oResGroup     = Data.Root.ChannelGroups.Add("Ereignisse -Filter-a-5-3 Y")
set oResGroupChns = oResGroup.Channels
call oResGroup.Activate
ChnEventList1 = ChnEventDetectionWindow("Zeit 1 - Standardmessrate", "Filter-a-5-3 Y", 0.3, 100, 0, 0)
ChnEventList1 = ChnEventFilter(ChnEventList1, "Peaks", 0.008, "Value")
ChnEventList2 = ChnEventDetectionWindow("Zeit 1 - Standardmessrate", "Filter-a-5-3 Y", -0.3, -100, 0, 0)
ChnEventList2 = ChnEventFilter(ChnEventList2, "Peaks", 0.008, "Value")
iNoOfMatches = ChnEventCount(ChnEventResultList)
msgbox iNoOfMatches
Call ChnEventCreateXYChannels("Zeit 1 - Standardmessrate", "Filter-a-5-3 Y", ChnEventResultList)
for iLoop = 1 to (iNoOfMatches * 2) step 2
  oResGroupChns(iLoop).XRelation     = Nothing
  oResGroupChns(iLoop + 1).XRelation = oResGroupChns(iLoop)
next
Message 34 of 35
(608 Views)
Hi Walter,
Thank you very much
I don't understand the code here very well.
next
Can you please explain it according to the example?
Best regards
Message 35 of 35
(597 Views)
