DIAdem
accessing the script log file contents
I would like to know the contents of the script log at a customer's site.   since we run DIADEM as a service,  it is not possible to  'see' the log.
are the contents stored somewhere?
is it possible to access (programatically) and write out contents?
jim
(3,871 Views)
Hello Jim!
The log is stored in a file. The filename with path is the concation of the variables DeskDrv and LogFilename. How verbose DIAdem is can be set via the LogFileExtent variable (see help) and in your script you can write to the log with the LogfileWrite command.
Hope this helps
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,869 Views)
