ni.com checkout is currently experiencing issues.
Support teams are actively working on the resolution.
07-26-2018 04:00 AM - edited 07-26-2018 04:01 AM
Dear All,
could you tell me which unit should be on z-axis in calculated JTFA spectrograms?
My data is time (s) vs. velocity (mm/s).
Thank you in advance.
BR,
Krzysztof
07-31-2018 06:21 AM
Hi Krzysztof,
I'm not fully sure I understand your question, should it be: what is the unit returned by the function for z-axis?
Could you please please tell me exactly which function you use?
In the meantime, let me add a link which you may find helpful: http://www.ni.com/tutorial/3549/en/
Mateusz
08-03-2018 12:27 AM
Dear Mateusz,
Thank you for quick response. I am wondering which method is used to calculate JTFS. Is it Short time Fourier transform? If yes, then what is the unit returned by the function for z-axis?
I have described my problem in attached .docx file.
Krzysztof
08-03-2018 01:47 AM
Hi Krzysztof,
Can you please confirm that you are using functions from Example Programs section of our webpage, which is: http://www.ni.com/example/28940/en/
