DIAdem
Y axis range - Rounding Up
I am having an issue with setting the y-axis on my report.
I want to display a range of 300 on the y-axis.
- fixed numbers don't work.  depending on the data sets, the values can be anywhere from 0 - 5000.
- using the "range and tick" option doesn't work due to occasional spikes in the data.  (i.e.  most values are 200-500, but because of 2500 spike, range option sets y axis to 900-1200)
- i can use D2AxisYBegin, 'End, 'Origin.  I know how to set those using scripting.  So I found the median of the channel and want to round down to the nearest hundred and set that as my 'Begin so that I don't have weird 'Begin and 'End values.
Is there a way to round on the left side of the decimal?  (i.e. 1265 --> 1200)
(4,185 Views)
Please try this :
MsgBox(Fix(1265/100)*100)
(4,182 Views)
