DIAdem
Writing calculated results always in the same file (.tdms, .xls or .csv file)
i struggle with the following problem.
I use a script, were i can open numerous files, calculating the peak values of a certain channel and saves the evaluated file again:
Option Explicit
Dim i
If FileDlgShow(DataReadPath,"TDM Files,*.tdm","DataSelection",True) = "IDOk" Then
For i = 0 to UBound(FileDlgNameList)
Call Data.Root.Clear()
Call DataFileLoad(FileDlgNameList(i),"TDM","Load")
Set ChnResult = ChnPeakDetect("[1]/valve_current_filt", "[1]/hysteresis", "/Position", "/Amplitude", "Peaks", 0, 3)
Call DataFileSave("Serie_"&str(i),"TDM")
Next
End If
Is there a chance to write the results (X- and Y-Values) in always the same file?
Thank you very much
best regards,
Udo
(1,338 Views)
My understand of your question is that after you execute ChnPeakDetect() and the two new channels are created, you want to update the same file with the new channel data (not create a new file).  The example below is a solution to that problem.
Spoiler
Dim oChnX, oChnY, oChnPeakX, oChnPeakY
'Get some data and save it to a new file
'DataReadPath = C:\Users\Public\Documents\National Instruments\DIAdem 2021\Data\
If FileExist(DataReadPath & "ChnPeakDetect_SourceData.tdm") Then Call FileDelete(DataReadPath & "ChnPeakDetect_SourceData.tdm")
Call DataFileLoadSel(DataReadPath & "Example.tdms", "TDMS", "[1]/Time|[1]/Speed")
Call DataFileSave(DataReadPath & "ChnPeakDetect_SourceData.tdm", "TDM")
'Load the new data file, assign channel variables, execute ChnPeakDetect(), save the file
Call DataFileLoad(DataReadPath & "ChnPeakDetect_SourceData.tdm", "TDM", "Load")
'Call ChnPeakDetect("[1]/Time", "[1]/Speed", "/SpeedPeakX", "/SpeedPeakY", "Peaks", 0, 3)
Set oChnX = Data.Root.ChannelGroups(1).Channels("Time")
Set oChnY = Data.Root.ChannelGroups(1).Channels("Speed")
Set oChnPeakX = Data.Root.ChannelGroups(1).Channels.Add("SpeedPeakX",DataTypeChnFloat64)
Set oChnPeakY = Data.Root.ChannelGroups(1).Channels.Add("SpeedPeakY",DataTypeChnFloat64)
Call ChnPeakDetect(oChnX, oChnY, oChnPeakX, oChnPeakY, "Peaks", 0, 3)
So the modification to your original code would be:
Spoiler
Dim i
Call DataFileSave(FileDlgNameList(i),"TDM")
Next
End If
(1,281 Views)
