DIAdem
ValueMaxCount Datafinder object
Hello All ,
I would like to limit the number of results. "oMyDataFinder.ValueMaxCount = 50" doesn't work in this combination. the Number of results is allways 200 (like default).
Where is my mistake?
Dim oMyDataFinder, oMyQuery, MyDate, MyMin, oMyResults
Set oMyDataFinder = Navigator.ConnectDataFinder(Test@test)
If oMyDataFinder.Name = Test@test Then
 Dim AdvancedQuery
Set  AdvancedQuery =Navigator.CreateQuery(eAdvancedQuery)
AdvancedQuery.ReturnType=eSearchFile
call AdvancedQuery.Conditions.Add(eSearchFile,"FILENAME","=", "*")
oMyDataFinder.Search(AdvancedQuery)
Set oMyResults = oMyDataFinder.Results
end if
Yustas
(3,758 Views)
Number of search results returned by DataFinder is defined by MaxCount of DataFinder.Result
(3,756 Views)
Accepted by topic author Yustas
Hi Yustas,
DataFinder.ValueMaxCount restricts the number of indexed values for one property, returned by GetValueList. For example:
oMyDataFinder.ValueMaxCount = 60
Dim oIndexedProperties, oIndexedProperty
Set oIndexedProperties = oMyDataFinder.GetIndexedProperties(eSearchChannel)
Set oIndexedProperty = oIndexedProperties("name")
msgbox oIndexedProperty.GetValueList.Count
To restrict the number of results try this:
oMyResults.MaxCount = 50
msgbox  oMyResults.Count
Hope that helps,
Eva
(3,755 Views)
it works,
thanks.
Yustas.
(3,725 Views)
