DIAdem
Value dependent calculation??
Hi, I couldn't find a method to make a calculation in Diadem, which affects only one row in the table.  What I need, is to calculate the value of 2 cells dependent on the value of a third one (<, = or >) and to save the calculated value in a new column.  And this shall continue, until the end of the column is reached.  Can someone help me with the VBA code??  Thanks in advance.
Sincerely yours, Hristo Arnaudov
(3,781 Views)
Hello Hristo Arnaudov,
You can create a loop over channel 3, check the value with the function ChD and depending on the result you calculate channel 1 or channel 2. But you can use the formula calculater too. And that's much faster than the loop. Please find attached an example.
Greetings
Walter
(3,777 Views)
🙂 Thanks a lot, the calculator expresion is realy easier to use.
(3,762 Views)
