DIAdem
VBS to Python Syntax
The following command works fine in a VBS script but I'm having trouble converting it to Python script with Diadem.
First is in VBS, second is in Python. The script documentation doesn't appear to have any python specific examples yet.
k = Find("Ch(""[2]/[7]"")>1",1)
k = dd.Find("Ch(""[1]/[29]"")>1",1)
(2,589 Views)
Accepted by topic author DTS_PBO
The problem is that double- double quote ("").
In VBS, that is the escape to add a " within a string. In Python it is \" instead.
So you can write:
k = dd.find("Ch(\"[1]/[2]\")>10",1)
Or, even better, since Python supports both ' and " as beginning of a string:
k = dd.find('Ch("[1]/[2]")>10',1)
In this way, you don't need any escape!
(2,559 Views)
That's got it! Thanks for the help and detailed explanation.
(2,551 Views)
