DIAdem
VBC: Error "Opening bracket is missing!"
Hi
in my application in Labview I call some VBS script in DIAdem.
I'd like to encrypt these scripts. But when I run a VBC script in labview I got this error:
Error in script - translation in line: 1 [TecNAS.VBC]
Someone can help me?
Thanks a lot
(3,476 Views)
Hi Michele,
It turns out that the "DIAdem Run Script.vi" doesn't work for VBC files.  It should, and I will tell R&D to fix this, but there is a simple parsing error in this VI for the case of VBC files.  You can successfully call your VBC file if you instead pass the following execution line to the DIAdem Run Automation command.vi:
ScriptStart('C:\Wherever\It\Is\TecNAS.VBC')
Note that I made up the file path to the VBC file-- you would need to supply the correct full path.
Brad Turpin
DIAdem Product Support Engineer
(3,464 Views)
