DIAdem
Text formating TDR if condition
Hi everyone.
Until now I was able to get some values and data in the TDR in function of the file I open, which is nice. However, I would love to write a specific text in function of the file I open.
Example, the file I open has a format x_y_z is called 1_2_3
I want then if x = 1 the title will be for example "First test type", if x = 2, "Second test type" etc. Same for the other ones. (y = 1, "DOW", y = 2, "GVW")  etc.
I managed to get the numbers with a split, for example for the run number, I take the last value like this:
@@Split(data.Root.Name, "_", -1, VBTextCompare)(Ubound(split(data.Root.Name, "_", -1, VBTextCompare)))@@
Any suggestion? Thanks,
L911
(3,568 Views)
Hi L911,
I am unsure of what you are trying to achieve. In my understanding, you have a file named something like X_Y_Z and depending on the value of X, Y and Z you want to achieve a certain kind of post processing. Am i right ?
CLAMaxime -- Kudos are a great way to say thank you
(3,518 Views)
Accepted by topic author L911
Like this?Like this?
(3,488 Views)
Hi Brad, Hi Gsklyr,
Sorry for the delay.
Indeed that is what I what looking for, the "IIF" function.
I assumed that to use it, we have to write @@IIF(condition, iftrue, ifwrong)@@
Is there a similar command for a switch case?
(3,482 Views)
