DIAdem
Text Control Text Not Centred?
I have a dialog box with a text control that is being used as a title. I centred the text only to find that when the text started on a new line it was actually left justified rather than fully centred as per familiar applications.
So, instead of this:
My Long Title That Runs
To Two Lines
I got this:
To Two Lines
Is it possible to fully centre text in DIAdem controls?
Regards.
(3,874 Views)
I meant to add: if you place the cursor in the text box then the centring is 'correct' (i.e. as per my expectations), but when you leave the text box the text is changed to the format I described.
Regards.
(3,859 Views)
Hello Simon_Aldworth,
If you use the setting
for the edit box it works fine on my side.
Tested with DIAdem 2022
Greetings
Walter
(3,835 Views)
Hi Walter,
Thanks for your reply. Sorry to point this out but you've misread my post. I'm using a text control. Centring text in an Editbox seems to work fine but not in a Text control. I'm using 2022 Q4.
Regards.
(3,819 Views)
Hi Simon_Aldworth,
You are right, I am sorry. This seems to be a bug and I will inform R&D about it. In the meantime you can use the following settings for the Edit Box to have a similar "feeling" as the Text Control.
Greetings
Walter
(3,807 Views)
Accepted by topic author Simon_Aldworth
Thanks Walter.
In the end I removed enough words to fit them all on one line!
Hope the bug gets fixed soon.
Regards.
(3,798 Views)
