DIAdem
String data passed to DDC_SetDataValues
Using the DIAdem connectivity library, you can call DDC_SetDataValues to store data in a channel. If the channel contains string data, what is the format for the values parameter? My guess would be a sequence of back-to-back null-terminated strings but the API documentation does not say.
(4,316 Views)
Hi hrodstein,
Are you using NI's software CVI, or are you using a MicroSoft C compiler?
Brad Turpin
DIAdem Product Support Engineer
(4,300 Views)
I'm using MS Visual C++ 2005 with the DIAdem Connectivity Library DLL API.
(4,278 Views)
Accepted by topic author hrodstein
I figured this out. When storing string data, DDC_SetDataValues takes a pointer to an array of pointers to C strings, like DDC_GetDataValues.
This is documented for  DDC_GetDataValues. It should also be documented for DDC_SetDataValues.
(4,266 Views)
