DIAdem
Set page layout setting
How to set report page layout set to particular user defined setting [ make it default and use this setting] ?
Height: 11
Width: 8.5
standard letter size used in US.
whenever I set the settings in page layout, it applies. After sometime, which i click page layout option, it doesnt show the values i set, it shows something default settings. Its confusing, which values are applied to report template.
please guide me on this.
regards,
Durai
(938 Views)
Hi Durai26,
if you define in REPORT via Settings->Layout Setup->Layout Parameters on tab "Worksheet" the page format than this is saved to your
used layout, which can also be reused as *.tdr file.
When you then click on "New Layout", then the definition from the standard layout is used, and not from the one with the changes you have created.
You can either manually load it or set this layout as standard layout in the DIAdem settings.
An overview about the different options for layouts can be found here:
https://www.ni.com/docs/en-US/bundle/diadem/page/concepts/diadem_5_031.html
(873 Views)
