DIAdem
Select channels programatically?
I developed a little script to search through the channel names in the data portal.  Entering the beginning or partial name of a channel gives a list of all channels that match.  After they find the channel(s) they are looking for, I have given them the option to put these channels in a graph or table in REPORT or VIEW.  I thought it would be neat to also give the option to "select" the channels in the data portal, so they could do what they would like with them.  I cannot seem to find if I can do this programatically though.
Thank you!
Julia Moeller
(4,243 Views)
Hi Julia:
You would have to use the ChnGet function to access Channels in the data portal programatically. The format for this function is
Call ChnGet(ChnSingleNo, ChnMultiNo, ChnGetTitle)
Thank you
Nandini
NI
(4,217 Views)
I have created a Community Example Program which may be of your interest: it performs a filtered group and channel search using dialog.
Filtered Data Portal Search with DIAdem Dialog - Discussion Forums - National Instruments
https://forums.ni.com/t5/Example-Program-Drafts/Filtered-Data-Portal-Search-with-DIAdem-Dialog/ta-p/...
Eric H.
Applications Engineering
(3,307 Views)
Hello Julia,
can you explain why it was necessary to develop a script instead of using the built-in filtering from the Data-Portal ?
Thanks for explaining.
Andreas
(3,301 Views)
Hi Julia,
Did you find the programmatic channel selection function for the Data Portal?  All programming in the Data Portal these days starts with the "Portal" object.
Brad Turpin
DIAdem Product Support Engineer
National instruments
(3,296 Views)
