DIAdem
ScriptDefault folder location version specific
Hello all.
Just a quick question about the scriptdefault.vbs file.  In what version did the file get moved from the ProgramDrv & AddInfo folder to the ProgramDrv & Libr\Documents folder?  I'm working with a user base spanning multiple versions so I would like to know.  Thanks very much.
Ben
(5,946 Views)
Accepted by topic author benb61794
Hi Ben,
Prior to DIAdem 10.2 the path was:
  ProgramDrv & "AddInfo\ScriptDefault.VBS"
For DIAdem 10.2 and later the path is:
  ProgramDrv & "Libr\Documents\ScriptDefault.VBS"
Brad Turpin
DIAdem Product Support Engineer
(5,932 Views)
Thank you thats what I needed, I was seeing several different references to what version it actually changed in, so I figured it best to just ask.
Again thank you it is much appreciated.
(5,929 Views)
