DIAdem
Scalar vs Vector units in quantity based calculation
How do I specify in Diadem that I want to work with a vector unit, not a scalar unit, when doing quantity based calculation.
Specifically, when calculating engine power, the equation is "power = engine speed * torque".  With quantity based calculation, this works fine and produces Watts.  But, if I try "torque = power / engine speed", I get Joules (which is scalar Nm), since it seems Diadem assumes scalar quantities.  Is there any way to get Nm the vector quantity instead?
(4,653 Views)
I think I need to clarify a little.  It does appear that the Power = Speed * Torque and Torque = Power / Speed works.  I thought that would be easier to explain, but I guess I should be specific...  Anyway, Mean Effective Pressure is (work/cycle)/Displacement.  So MEP (bar) = 0.1257 * [Torque(Nm)/displacement(Liter)].  I can calculate MEP by dividing torque by displacement, but if I multiply MEP by displacement, I get Joules.  Anyway to get Nm with the calculator.
I have a very large calculation function that takes in a table of calculations with a target unit.  If I put desired unit of Nm into the calculate function when the result is J, I get an error, even though they are the same value.
(4,640 Views)
Hi RussellSenior,
I'm still not clear on exactly what is going on. Can you provide some screen shots?
(4,612 Views)
So, I must have changed something... The other day, when I ran this script, and asked for the second desired unit to be in Nm, I got an error saying Diadem cannot convert J to Nm.  But, now it's doing it no problem...
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Dim MyValues(2), MySymbol(2), MyUnit(2), DesiredUnit, MyFormula, CQB
CQB=CalcQuantityBased
CalcQuantityBased=true
Set MyValues(0) = CreateValueWithUnit(360,"ft-lb")
Set MyValues(1) = CreateValueWithUnit(5,"l")
Set MyValues(2) = CreateValueWithUnit(Null,"")
MySymbol(0)="Torque"
MySymbol(1)="Displacement"
MySymbol(2)="MEP"
MyFormula="MEP = Torque / Displacement"
DesiredUnit="bar"
Call Calculate(MyFormula,MySymbol,MyValues,DesiredUnit)
MsgBox("Result: " & Round(MyValues(2).Value,2) & " " & MyValues(2).UnitSymbol)
DesiredUnit="default"
'DesiredUnit="Nm"
MyFormula="Torque = MEP * Displacement"
MsgBox("Result: " & Round(MyValues(0).Value,0) & " " & MyValues(0).UnitSymbol)
CalcQuantityBased = CQB
(4,598 Views)
Interesting... Well, if the problem surfaces again, don't hesitate to post.
(4,589 Views)
