DIAdem
Saving R32 data files as csv
I'm new to DIAdem and VB scripts and want to convert data files automatically to csv. I have a "data.DAT", "data.R32" and "data.TSX" file for multiple "data"s.
If I run the following code, only the header information from "data.DAT" is saved in the csv:
ElementList = DataFileLoad("data.DAT", "DAT", "LoadImmediately")
Call DataFileSave("data.CSV", "CSV")
How can I also save the data from "data.R32" in the CSV?
(3,788 Views)
I added
Call Data.Root.Clear()
so the code looks like this
and the real data is now saved to the csv.
Sadly, only the first ~250k lines match the resulting csv when I export the data by hand. The following 2 million lines are empty but with some newlines or tabs. Both files have the same number of lines.
Does someone now this issue?
(3,783 Views)
I tried the following
Option Explicit
data.Root.clear
call ChnGeoGen("/GeometricGenerated1",1,30,2250000,"")
call ChnGeoGen("/GeometricGenerated2",1,40,2250000,"")
call ChnGeoGen("/GeometricGenerated3",1,50,2250000,"")
call ChnGeoGen("/GeometricGenerated4",1,60,2250000,"")
Call DataFileSave("C:\temp\out.CSV", "CSV")
Which creates a CSV file with the according values.
How many channels do you save.
Is it possible that it is an memory issue? Can you check in Process Explorer?
(3,747 Views)
Hi Andreas,
your code works fine and produces a file with 2250000 lines.
I have 42 channels in my data and the export uses maximal 700MB RAM with circa 5GB free.
Another origin of the problem could be that I use Windows in a VM but I don't believe so.
Thanks for your help!
(3,733 Views)
Can you add some information?
  • DIAdem Version
  • Bitness 64/32 bit
  • Windows version
P.S.:I assume sending an example file does not work because even zipped it is to big. Right?
(3,697 Views)
