DIAdem
SQL_insert in Diadem 8
I would like to copy the path of a measurement file in an access-Database with the command "SQL_insert" (I'm still working with Diadem 8):
Problem: The Path contains an apostrophe:
T3:='c:\va's_neu\test';
SQL_INSERT('mes_Leistung_konst','Ablablagepfad',T3);
produces an error message
I tried the following commands:
SQL_Connect('Versuchsauftrag_be','user1','','');
SQL_INSERT('mes_Leistung_konst','VANr','va's');
SQL_Disconnect;
-> error mesage: Fehler in Autosequenz - Übersetzung in Zeile: 3 - Autosequenz - Texte müssen in Hochkommata eingeschlossen sein
SQL_INSERT('mes_Leistung_konst','VANr',"va's");
SQL_Disconnect;
-> error mesage:
Fehler im ODBC-Befehl: [Microsoft][ODBC Microsoft Access Driver] Syntax error in string in querry expression 'va's)'. SQL: INSERT INTO mes_Leistung_konst (VANr) VALUES (va's)
Is there al solution for this Problem? Perhaps with the SQL_ExecDirect-command?
Thanks a lot!
Markus
(3,369 Views)
Hello Markus!
SQL_INSERT('Tabelle1','Test',"'va''s'");
worked on a 'Text' field in an Access DB.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,357 Views)
Hello Matthias,
That works,
thank you very much!
Markus
(3,341 Views)
