DIAdem
SQL Datetime conversion
I'm having problems converting a SQL datetime column into a DIAdem timestamp in the correct format - I'm getting the month & days mixed up. I.e my logged data is a series of rows for 4th, 5th & 6th October, but imports to DIAdem as 10th April, 10th May, 10th July....
I've tried various methods, the latest was Brad's code below using ADO to import the 'Timestamp2' column. I've also tried adjusting DIAdem's time display setting, this doesn;t make any difference.
' needs to be set to a valid ADO connection string for data base
ConnectionStr =
"DSN=dc; Uid=; Pwd=;"
' construct the SQL query to execute
Table   =
"HMI_Data"
ColStr  =
"Timestamp2,PT_1_004,PT_1_085"
'CondStr = " WHERE sensor_id=2"
'SortStr = " ORDER BY Timestamp2"
QueryStr =
"SELECT " & ColStr & " FROM " & Table
'QueryStr = "SELECT " & ColStr & " FROM " & Table & CondStr & SortStr
MsgBox
QueryStr
' Connect to the data base
Set
ADO = CreateObject("ADODB.Connection")
ADO.Open ConnectionStr
' Execute the query and import the resulting data records into a VBScript variable
Set
RecordSet = ADO.Execute(QueryStr)
RowVals = RecordSet.GetRows()
ChanNames =
Split(ColStr, ",")
' Send the resulting data records from the query to new channels in the Data Portal
Call
DataDelAll
Call
GroupCreate(Table)
Call
GroupDefaultSet(GroupCount)
Channels =
ArrayToChannels(RowVals, ChanNames, 1)
' Disconnect from the database and output the query used and any errors
ADO.Close
How can I adjust / edit the time format when I import it?
Thanks... Martin
(5,584 Views)
Hi Martin,
Usually a data base column that is of datatype DateTime loads flawlessly into a DIAdem channel of datatype DataTime with the code you posted.  What datatype is that "Timestamp2" column you're loading?  What datatype is the resulting DIAdem channel-- DateTime or String?  If you're getting a String channel in DIAdem because you have a String column in the data base, then I can help you convert the resulting String channel to a correct DateTime channel.
Brad Turpin
DIAdem Product Support Engineer
(5,561 Views)
