DIAdem
Running Diadem From Within VB.NET
I use the following snippet of code that works for my needs using VB.NET
oDiadem = New DIAdem.TOCommand
'Save Diadem file as TDM in the specified folder.
nDiademStatus = oDiadem.TextVarSet("T3", sFolderPath & "\" & sFileName & ".TDM")
oDiadem.CmdExecuteSync("DataFileSave(T3, 'TDM')")
'Close down diadem
oDiadem.CmdExecuteSync("DataDelAll(1)")
nDiademStatus = oDiadem.TextVarSet("T3", "ignore") '
oDiadem.CmdExecuteSync("FileModification:= T3")
oDiadem.CmdExecuteSync("ProgramExit()")
oDiadem = Nothing
The file save works fine, but at the "ProgramExit()" call. I get the following error (see attached screen shot)
Clicking OK closes the dialog by the instance of Diadem remains running in memory
(2,960 Views)
I use:
FileModification = "ignore" ' Just like you do in code pasted below
' nDiademStatus = oDiadem.TextVarSet("T3", "ignore") '
' oDiadem.CmdExecuteSync("FileModification:= T3") ' Instead of Call ProgramExit() i use: Application.Exit()
I do this in DIAdem script so the last line would look different in your code
(2,953 Views)
Hi
Thanks for the suggestion but it does not work for application.
Tried the following :
oDiadem.CmdExecuteSync("Exit()")
and
oDiadem.CmdExecuteSync("ApplicationExit()")
Also tried using the CmdExecuteAscync, but still get the same error.
(2,946 Views)
if DIAdem wasn't started before it will disappear if ODIAdem is destroyed.
Dim oDIAdem, iSuccess
Set oDIAdem = CreateObject("DIAdem.TOCommand")
If Not oDIAdem.bInterfaceLocked then
  iSuccess = oDIAdem.CmdExecuteSync("MsgBoxDisp(""hello"")")
End If
If you run this using cscript you will see DIAdem start show Message box and disappear.
I am not sure how it is made sure in .net garbage collection that the object is destroyed.
(2,908 Views)
